1. Tarek Fahmi's Avatar
    (I have the exynos variant if that is at all relevant to the issue)
    When i use the fast charging cable and brick that come with the s9, i get an estimated charge time of over 2 hours, and when i toggle fast charge on and off in the advanced battery settings, it doesnt change at all. With fast charging on or not. Could it be the cable?
    06-18-2018 01:00 PM
  2. dpham00's Avatar
    Is it saying fast charging in the notification panel? If not then it is either the cable, the charger or the phone. All components should be under warranty from Samsung.
    06-18-2018 04:13 PM
  3. Tarek Fahmi's Avatar
    It says fast charging in the notification panel. When I toggle fast charging off in the advanced battery settings, the time remains the same. When i toggle it on again, still no difference. Really starting to **** me off.
    06-19-2018 11:41 AM
  4. bbgpsuser's Avatar
    How much battery is left when you start the fast charging? If the battery is low enough, it may take 2 hours of fast charging to fully charge it.
    06-20-2018 01:16 PM
  5. Tarek Fahmi's Avatar
    It takes about 2 and a half hours to go from 0-100
    06-23-2018 12:28 PM
  6. lucianus_luciferus's Avatar
    That sounds about right
    06-24-2018 05:20 AM
  1. Is my Galaxy S9+ battery having some problems?
    By MachidoKH in forum Ask a Question
    Last Post: 06-20-2018, 02:39 AM
  2. How long should fast charging take on the s9?
    By Tarek Fahmi in forum Samsung Galaxy S9 & S9+
    Last Post: 06-19-2018, 12:23 PM
  3. S8 is pulsing and won't turn on
    By hmoney29 in forum Samsung Galaxy S8 & S8+
    Last Post: 06-18-2018, 12:51 PM
  4. Why my S9+ Wifi turns off after screen locks and does not want to turn on again?
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 06-18-2018, 07:41 AM
  5. Why my S9+ Wifi turns off after screen locks and does not want to turn on again?
