1. Ninjawarrioruk77's Avatar
    I'm having issue's where it seems my s9 plus can't pick up a signal at all on occasions when restarting the phone it won't show a network at all and the only way to get the signal back is to turn on flight mode off then on...Could it be a hardware issue ?
    it's as if mobile network had been switched off, It's only happened 2 times but I have only owned it less than 2 weeks
    Should I get the handset exchanged?
    06-25-2018 07:50 PM
  2. Almeuit's Avatar
    Which carrier are you on?
    06-25-2018 11:32 PM
  3. speed13's Avatar
    After recent T-Mobile software update I have many issue while searching on the web. Looks like loosing network or connectivity while browsing and using T-Mobile network along with wife.
    Had to reboot my phone multiple times in order to work and works for short period and all over again.
    06-25-2018 11:41 PM
  4. speed13's Avatar
    You should do network reset
    06-26-2018 11:51 AM
  1. Replies: 3
    Last Post: 07-26-2018, 03:12 PM
  2. Replies: 5
    Last Post: 06-27-2018, 02:17 AM
  3. Replies: 2
    Last Post: 06-25-2018, 05:22 PM
  4. Unlock a at&t lg G6 that the keyboard does not appear on, no wifi
    Last Post: 06-25-2018, 03:36 PM
  5. the app Message for receive sms give not the date and time of emission
    Last Post: 06-25-2018, 01:54 PM
