    I don't want to turn the notification reminder off, I just want to change the sound file
    06-29-2018 12:03 AM
  2. Rukbat's Avatar
    Open the reminder app, look for a menu (3 lines at the top left or 3 dots at the top right), tap that and look for Settings. You should find Notifications in there, and you should be able to change the notification sound. If you can't, it's using the phone's default notification, and that's in the phone's Settings - pull down the notification shade and tap the gear. Go to Apps & notifications, then to Notifications, then to Default notification sound, and change it there.
    06-29-2018 01:03 PM
  1. My blue light filter turns itself on
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 07-16-2018, 09:20 PM
  2. Android Messages contact tones
    By 45Shield in forum Ask a Question
    Last Post: 06-29-2018, 01:06 PM
  3. Stop notification sound for slow charging
    Last Post: 06-29-2018, 05:43 AM
  4. file format is not supported ,when trying to share the file in Musical.ly
    Last Post: 06-29-2018, 02:03 AM
  5. How do you turn on url settings for messaging
    Last Post: 06-28-2018, 11:20 PM
