Abbers727 Well-known member Sep 21, 2015 371 2 16 Visit site Jul 4, 2018 #1 I get this pop up sometimes when I turn off my wifi. It says 'unable to establish a wireless data connection' I was wondering if there was a setting I needed to change or something before I go to a sprint store to try to fix the issue.
Rukbat Retired Moderator Feb 12, 2012 44,529 26 0 Visit site Jul 4, 2018 #2 Turn on mobile data before turning off wifi. If mobile data is off and you turn off wifi, there's nothing left that's turned on.
Abbers727 Well-known member Sep 21, 2015 371 2 16 Visit site Jul 4, 2018 #3 Rukbat said: Turn on mobile data before turning off wifi. If mobile data is off and you turn off wifi, there's nothing left that's turned on. Click to expand... I always have mobile data on. Should I turn off the Wifi power saving mode?
Abbers727 Well-known member Sep 21, 2015 371 2 16 Visit site Jul 4, 2018 #4 Maybe I needed to turn this on.... To fix the issue?? I'm not sure.
