1. Abbers727's Avatar
    I get this pop up sometimes when I turn off my wifi.
    It says 'unable to establish a wireless data connection'
    I was wondering if there was a setting I needed to change or something before I go to a sprint store to try to fix the issue. Unable to establish a wireless data connection-screenshot_20180622-085018_samsung-20experience-20home.jpg
    07-04-2018 01:28 PM
  2. Rukbat's Avatar
    Turn on mobile data before turning off wifi. If mobile data is off and you turn off wifi, there's nothing left that's turned on.
    07-04-2018 02:03 PM
  3. Abbers727's Avatar
    I always have mobile data on. Should I turn off the Wifi power saving mode?
    07-04-2018 02:08 PM
  4. Abbers727's Avatar
    Maybe I needed to turn this on....
    To fix the issue?? I'm not sure. Unable to establish a wireless data connection-20180704_134636.jpg
    07-04-2018 02:47 PM
  1. Upgrade to 7.1.1
    By Mrs._djs in forum Android 7.0 Nougat
    Last Post: 07-04-2018, 03:33 PM
  2. Huawei P20 Pro Wifi connectivity speed
    Last Post: 07-04-2018, 02:06 PM
  3. Replies: 1
    Last Post: 07-04-2018, 01:43 PM
  4. how a can put my LG-V10 Data Working ?
    Last Post: 07-04-2018, 01:41 PM
  5. I need some help figuring out what phone to get next
    Last Post: 07-04-2018, 11:49 AM
