    Are there lots of pocket dials and other irritating opening and closing of apps ?
    07-05-2018 09:36 AM
  2. ABOSWORTH007's Avatar
    I have never had an issue with it. I had a butt dial once because I forgot to lock the phone before I put it back in my pocket but that's not the fault of the phone. I have mine set to require the fingerprint immediately upon locking rather than after a set amount of time. I think that is where people run into issues. I do not personally find that I open apps by accident. I had that problem with the edge screen on the S7 Edge but I felt that that particular problem was addressed with the S8 models.
    Another thing, if you answer a text message and then just put the phone in your pocket, it's going to dial whoever you're texting if you have the "raise to call" feature or whatever it's called enabled. People need to realized that as well.
    07-05-2018 01:17 PM
  3. SDTRMG's Avatar
    not if you have a lock on your device, I haven't used it without so I couldn't say
    07-06-2018 01:32 AM
  4. filanto's Avatar
    haven't had any issues with my S8 unless I'm eating salty snacks
    07-06-2018 03:52 AM
  1. Chrome bookmarks on S9
    By StoneyC2018 in forum Samsung Galaxy S9 & S9+
    Last Post: 07-06-2018, 01:22 PM
  2. Replies: 5
    Last Post: 07-06-2018, 09:20 AM
  3. How to disable in-app vibration in whatsapp?
    Last Post: 07-05-2018, 05:01 PM
  4. Replies: 2
    Last Post: 07-05-2018, 02:29 PM
  5. What can I delete in my media files to prevent insuffient storage? prevent
    Last Post: 07-05-2018, 01:34 PM
