    Galaxy s9. Updated earlier this week and the standby screen (screen with clock and date swipe to unlock) is suddenly missing. The phone will still lock after the designated 10min and require my password, but in the meantime pressing the power button completely skips the standby screen and directly opens the phone (no swipe required). I am not using Smart Lock or hard press to bypass lock screen options. I ran in safe mode to see if it was an app that I downloaded preventing sleeping (similar to what google maps does) but still had the problem. Any ideas?
    belodion likes this.
    07-05-2018 03:40 PM
  2. belodion's Avatar
    Well done for trying Safe Mode.
    Moved to S9.
    07-05-2018 04:44 PM
  3. osubass1's Avatar
    i just upgraded to ARF4 on my AT&T S9 and noticed there is no lock screen anymore. (unless the phone is locked)
    i don't normally use the power button, i usually press the home button, and there's a setting to make it so pressing the home button skips the lock screen, but i don't have that option chosen.
    07-05-2018 07:58 PM
  4. Breadline's Avatar
    SETTINGS>LOCKSCREEN AND SECURITY>ALWAYS ON DISPLAY>"ALWAYS SHOW"
    Hope this worked. It fixed it for me. I was having your same problem
    08-27-2018 05:51 AM
  1. Why won't my phone connect to my computer using the USB cable?
    Last Post: 02-16-2019, 12:10 PM
  2. My phone's screen is locked horizontally. How can I fix it?
    Last Post: 07-05-2018, 11:25 PM
  3. Why won't my screen rotate?
    Last Post: 07-05-2018, 11:24 PM
  4. Unable to login to email account on Android email app
    Last Post: 07-05-2018, 11:23 PM
  5. How can I get the AT&T Startup Screen (boot)?
    Last Post: 07-05-2018, 03:28 PM
