1. GS5TR's Avatar
    Someone have some great battery saving tricks and tips? Since a week phone is getting hot all the time and battery draining while doing nothing? Phone is like 37.5° all the time. Hope someone can help me out.
    07-19-2018 10:09 AM
  2. Rukbat's Avatar
    It sounds like a short somewhere in the phone or the battery is shot. If you can't diagnose which, bring it to a repair shop - it's definitely not working right.
    Battery saving tip: Never charge the battery to over 80%. Never discharge the battery below 40%. (These are not deep-discharge batteries, and fully charging them has been seen to reduce their lives.) Constantly draining a battery down to the last drop can kill a brand new battery in a month.
    Denisew 1972 and Morty2264 like this.
    07-19-2018 01:24 PM
  3. bbgpsuser's Avatar
    In Settings -> Device Maintenance -> Battery what does is show is eating your battery?
    Similar to all the phones before this one, my wife charges her s9+ to 100% overnight and have never had a problem with battery life. Same for my Note 8.
    Denisew 1972 likes this.
    07-19-2018 07:05 PM
  4. karelj's Avatar
    Eh. I do the 80%-30% envelope for charging. I also disabled fast charging and only switch it on for when I've been negligent in paying attention to my charge status and need a quick fill up.
    But this partial charging should not be a barrier to occasionally charging to the full 100% for those instances when you know you're going to be out all day and most of the night.
    07-19-2018 07:11 PM
  5. rjack22's Avatar
    I leave my phone plugged in most of the time. Although my S9 is only 4 months old, I did the same thing with my old S6 and never saw a decrease in battery life.
    Ruikee likes this.
    07-19-2018 07:35 PM
  6. MrDoh's Avatar
    Yeah, been doing the same with my phones for years...plug them in overnight and they sit at 100% (or slightly less) for hours every night. Never had to replace a battery, no battery problems. I don't see any point on babying the batteries in my phones, they've all lasted the life of the phone. Of course, I don't discharge them below about 50%, and getting down to 50% is very rare.
    The part that bothers me about the OP's posting is the hot part. That sounds like something has gone wrong with app(s) or with the OS. I would first try a full factory reset to see if that fixes the heating problem. You can also boot the phone into "safe" mode, and run it that way for a while. That eliminates all the apps except the ones that come with the phone. That might tell you if you have an app gone wild or a rogue app.
    07-20-2018 03:18 AM
  7. Deepcuts's Avatar
    Best tip so far in my case: Disable the freaking Always on display. 1st test, it accounted for 20% of battery, on the lowest brightness.
    07-20-2018 08:03 AM
  8. DarkSorrow's Avatar
    I charge to 80% usually since I bought the phone. Sometimes I do a full if I'm not going to be around a charger or my 24500 mAh battery cell packs.
    07-20-2018 12:22 PM
  9. Rukbat's Avatar
    It depends on how long you're going to keep your phone. Until it breaks? Then charging to 100% will shorten the battery life. A year? Then it probably won't.
    But running it until the battery is dead all the time is different.
    07-20-2018 06:02 PM
  10. rjack22's Avatar
    I ran 2 1/2 years with no issues on my old S6.
    07-21-2018 05:33 AM
  11. karelj's Avatar
    I charge to 80% usually since I bought the phone. Sometimes I do a full if I'm not going to be around a charger or my 24500 mAh battery cell packs.https://uploads.tapatalk-cdn.com/201...d93a441ba0.jpghttps://uploads.tapatalk-cdn.com/201...95a0896f73.jpg
    Oof! 2.1% loss per hour while on standby?
    07-22-2018 05:13 PM
  12. Bankokbob54's Avatar
    I learned a lot from that Accu Battery app.
    08-07-2018 06:01 AM
  13. Hermes Hidayat's Avatar
    I disabled apps with package disabler. And i turn off background activity for instagram and everything's fine now.
    08-07-2018 08:02 AM
  14. Denisew 1972's Avatar
    Agree, I had my S6 edge from launch 2 plus years and never had an issue with consistantly charging overnight. Doing the same with my S9+ with awesome battery life. I'm happy with it anyway.
    08-07-2018 08:39 AM
  15. electricpete's Avatar
    I agree with you. it's definitely true that staying in 40-80% range will help battery longevity. but "never" is way to strong a word
    08-08-2018 12:01 PM
  16. SamsungTechFan's Avatar
    Ok, this is going to have paid apps, but I will guarantee you that you will enjoy these apps and will appreciate it. I would change your whole theme to black, and by doing that download Substratum Theme Engine, and download Swift Black. Try learning how to use it, it's very easy once you know. It'll convert mostly everything black, including Instagram, YouTube, and more. I will guarantee you will love it because everything becomes black, so it'll use less pixels.
    Afterwards, download Package Disabler Pro. What that does is force disable things you normally can't in settings, and by disable I mean completely disable. Try disabling things you don't use like Bixby for example. You can disable all Bixby stuff, and that will save you a lot, because Bixby is constantly running in the background. In the app just put on search "Bixby", and disable all which are around 5-15 stuff. Reduce resolution size, and use black wallpapers.
    Those things will help a lot
    08-13-2018 04:34 PM
  17. methodman89's Avatar
    I charge about 10,000 lithium ion 18650s a day.
    There is a reason, chemically, to not charge lithium ion to 100 %on a normal basis, as it will shorten life. Draining it to 0 is also a killer.
    Our phones say they are at 100%, but somewhere in the code, the processor will allow only a trickle charge once charged to the engineers spec, which is going to be under 100%of available lithium ions as a safety and reliability practice. The notes on fire was an obvious lesson in this. A lot more battery fires would occur if everyone was actually charging to 100 and then doing intense processor work.
    Since most people keep a phone 2 years or so, leaving it on a charger at 100% will not be a noticeable degradation for most people.
    08-14-2018 07:27 AM
  18. Morty2264's Avatar
    I usually stop charging my phone well before it hits 100% - usually when it's between 80-84%. And if I've forgotten that it's been on the charger, I for sure try to unplug it before it gets to 90%. I also never let it sit on the charger overnight; just in case. Phone batteries are more resilient these days, but you never know.
    08-14-2018 07:36 AM
  19. Mojofilter9's Avatar
    What’s the point in having good battery health if you constantly limit yourself only using 40% of it’s capacity?
    Just charge and use your phone as is convenient and accept that in 3 years (if you keep it that long) the battery capacity will be down to 80ish percent - which is significantly less hassle and still double what someone keeping it between 40 and 80 all the time gets.
    methodman89 likes this.
    08-14-2018 05:17 PM
  1. Battery drain solution?
    By zajajo91 in forum Ask a Question
    Last Post: 08-03-2018, 12:04 PM
  2. Thoughts on the Galaxy Note series and a question about batteries
    By Lars Peter in forum Samsung Galaxy Note 8
    Last Post: 07-28-2018, 08:41 AM
  3. password not working, stuck in max power saving mode s6
    By Android Central Question in forum Samsung Galaxy S6
    Last Post: 07-19-2018, 01:28 PM
  4. Google Maps won't save my work / home addresses
    Last Post: 07-18-2018, 09:28 PM
  5. Replies: 1
    Last Post: 07-18-2018, 05:27 PM
