Wireless charging bug?
anon(7775)
183
When on my wireless charger my phone when it reaches 100 percent the screen will turn on then off repeatedly until I remove it. Using a fast wireless charger aftermarket though
SpookDroid
Ambassador
Jul 14, 2011
19,298
555
113
Unfortunately that's all on the charger. The protection circuit on your phone will prevent it from 'overcharging', but the charger is the one that turns itself on/off.
strikeIII
2,729
Do you happen to have a case with a metal plate in it for your car magnetic car mount? If so this maybe the cause. It happens to mine until I take the case off.
HNNNNNGHHH
675
Has to be your charger. My official Samsung branded fast wireless charging stand, pad, and convertible don't exhibit this issue. Haven't tested other chargers though.
SpookDroid
Ambassador
Jul 14, 2011
19,298
555
113
Samsung-branded ones work for me, Toyota in-vehicle works fine, and Seneo Fast Wireless stand also works OK (can power the phone after it's been fully charged).
Hermes Hidayat
2,617
38
I am currently using the Samsung wireless charger and Spigen F306W and they both work well. Would recommend Spigen as they include the QC3 charger.
samyblaze
