When on my wireless charger my phone when it reaches 100 percent the screen will turn on then off repeatedly until I remove it. Using a fast wireless charger aftermarket though
Do you happen to have a case with a metal plate in it for your car magnetic car mount? If so this maybe the cause. It happens to mine until I take the case off.
I am currently using the Samsung wireless charger and Spigen F306W and they both work well. Would recommend Spigen as they include the QC3 charger.
Just remember that Samsung's Phones aren't QC3-compatible (just QC2) so having the 'extra' speed step won't really matter.
