1. THEPRFCT10's Avatar
    Anyone know why when using the volume rocker switches if I push and hold to silent or vibrate it also does the notification volume which is good however when I go to bring the volume back up via on the rocker switch it only brings the ringtone volume up and keeps the notification volume either on silent or vibrate.
    07-25-2018 09:38 PM
  2. lucianus_luciferus's Avatar
    I've just tried this on my s9+ and it works fine. When I put the volume back up the notification volume goes up as well.
    Maybe you have an app that controls the volumes?
    07-26-2018 03:33 AM
  3. THEPRFCT10's Avatar
    Interesting but no I do not have an app that has anything to do with volume.
    07-26-2018 11:10 PM
  4. methodman89's Avatar
    Open the camera, go to the Settings, select Volume Key Function and change it to what you want.
    THEPRFCT10 likes this.
    07-27-2018 04:38 AM
  1. Android Auto adjusting volume of maps and Sirius XM
    Last Post: 07-25-2018, 03:03 PM
  2. Has anyone switched a Verizon S7 to Walmart Family Plan?
    Last Post: 07-23-2018, 06:16 PM
  3. Android Job scheduler behavior when device goes to sleep
    Last Post: 07-23-2018, 02:57 AM
  4. Unable to switch between WiFi networks S9+
    Last Post: 07-23-2018, 02:23 AM
  5. Samsung A5 2017 speaker volume low
    Last Post: 07-22-2018, 06:32 AM
