A
Android Central Question
Samsung S9 battery?
Hi! So recently I got a Samsung Galaxy S9. The thing is, even after using or scrolling through the phone for 10 minutes, my phone loses 1% so easily. Then, I noticed that every hour it loses 2-3%. I have tried to disable all the apps I dont need, disable display, even change my theme but it seems to be consuming a lot. I tried to factory reset without the stuff I transferred from my old phone and it's still decreasing a lot. Also, on my first setup the screen was very warm. Should I just return it? Or is that normal?
