1. hishaq96's Avatar
    Hi what's people's experiences with the upgrade from s7 edge to s9 plus is it worth it?
    09-09-2018 05:50 PM
  2. Gary_Berg's Avatar
    My wife was happy, she can see the screen outdoors. Double the storage helps, too.
    09-09-2018 06:46 PM
  3. Chris Lusardo's Avatar
    I've enjoyed it. For me, it took awhile to get used to not having the fingerprint sensor on the front.
    09-09-2018 08:12 PM
  4. waqqas31's Avatar
    The only thing that suffers is the sharpness of indoor and low-light pictures. The noise reduction in the S9+ crushes the detail, but if you only care about the way a picture looks when fully zoomed out, you will be ok.
    09-09-2018 08:26 PM
  5. hishaq96's Avatar
    How's the battery life?
    09-09-2018 11:19 PM
  6. anon(5719825)'s Avatar
    I have the US unlocked S9+ and the battery life on my phone beats any other phone I have ever had, even my Note 9 with it's bigger battery.
    I also had a US unlocked S8+ last year and it too had battery life as good as my S9+. I think the unlocked models have better battery life then the carrier versions. I started finding this out when I had a T-Mobile S7 Edge and a US unlocked S7 Edge. The unlocked version always had better battery life.
    09-10-2018 02:07 AM
  7. dpham00's Avatar
    It is not a huge difference but there are some improvements. The curve on the s9+ is way better than in the s7 edge, imo. There are other improvements like more accurate fps(albeit on the back) , louder speakers, faster cpu, more ram, better camera overall.
    09-10-2018 04:10 PM
  8. naturalguy's Avatar
    The camera is a huge upgrade
    09-10-2018 07:08 PM
  9. Hermes Hidayat's Avatar
    okay i might not have moved from S7 Edge to S9 Plus but moving from Note 8 to S9 Plus is already a big jump for me.
    and comparing the latest S series to a 2 year old S series isnt really comparable...but in my opinion if you can wait for S10 then you should.because S10 would have newer processors and bigger RAM.
    09-12-2018 08:11 PM
  1. How to recover data after accidental factory reset?
    Last Post: 09-09-2018, 05:08 PM
  2. Why s9 plus is not connecting to gear 3 fointer
    Last Post: 09-09-2018, 02:45 PM
  3. Problem with S7 front camera pink spot or star diamond
    By mikepl7 in forum Samsung Galaxy S7
    Last Post: 09-09-2018, 02:40 PM
  4. How to turn off swipe icon to unlock phone?
    Last Post: 09-09-2018, 02:13 PM
  5. Replies: 0
    Last Post: 09-09-2018, 01:29 PM
