1. Justanotherfrenchguy's Avatar
    Hey all, recently my GS9+ has been having this problem, and I cannot find any solution.
    When I receive a text, WhatsApp message or anything, they do not show up, and instead I get the Edge Screen lighting up, and get the small notification at the top of the screen.
    I haven't dropped the phone prior to this, so I am not sure what could have happened.
    I also do not think it has anything to do with the front sensor, as it doesn't show the "Touch input blocked" message.
    Does anyone know of a fix for this?
    09-17-2018 09:33 PM
  2. Hermes Hidayat's Avatar
    In the Edge Settings. You can set where you want to show the notifications. Or maybe Notifications and lock screen.
    09-18-2018 04:07 AM
  3. krisqz's Avatar
    I think that's the way Edge Screen works. Personally, I have it disabled because I prefer normal notifications. Also, make sure you have it set for Face Down only if you don't want edge screen with screen up.
    09-19-2018 04:57 AM
  1. Can't clear voicemail notification
    By nofaithineli in forum Samsung Galaxy Watch
    Last Post: 11-19-2018, 11:10 PM
  2. I have a dead spot on my screen
    Last Post: 09-18-2018, 07:03 AM
  3. Samsung Tab E Locked Up, Blue Line On Screen
    Last Post: 09-18-2018, 06:51 AM
  4. Which is best the Honor 7x or the ZTE Axon 7???
    Last Post: 09-17-2018, 09:14 PM
  5. What is placed into the folder "sstream.app".
    Last Post: 09-17-2018, 08:23 PM
