    Why do all calls made to my Samsung Galaxy S9 plus go straight to voicemail if the caller IS NOT IN my contacts? Sprint has been no help
    09-20-2018 04:31 AM
  2. krisqz's Avatar
    Do you have spam call protection enabled?
    09-20-2018 07:56 AM
  3. Rukbat's Avatar
    The default if the caller is in or is not in your contacts is to ring the phone until the amount of time set in the voicemail server (figure 5 seconds per ring then add 2). Phones don't automatically send "not in Contacts" calls to VM unless a) the particular phone is capable of it and b) you set it to do that ... or you've installed an app to do it.
    09-21-2018 02:41 PM
  1. why can't i install Rules of Survival App on my Samsung Note 9
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 09-21-2018, 03:42 PM
  2. Can i dedicate a smartphone to camera only for a child
    Last Post: 09-21-2018, 03:41 PM
  3. So what changes would you make to the Note 9?
    By BlackZeppelin in forum Samsung Galaxy Note 9
    Last Post: 09-20-2018, 09:03 PM
  4. Android with onboard Forwarded call notification!!
    Last Post: 09-20-2018, 02:53 PM
  5. How to stop battery low indicator
    By ctepu1 in forum Legacy Android & Other OS's
    Last Post: 09-20-2018, 05:12 AM
