    I recently switched from IOS to android when the galaxy S9 was released and my question is about AOD: ive set an AOD while i was discovering the phone however i used a GIF but set it as an imagine instead of a GIf (clock style vs other setting i cant remember the name of) but now i cant change it (the menu where there was a + sign to add an AOD is now replaced with the actual AOD GIF/imagine i set. Haaaalp!
    09-28-2018 06:10 AM
  2. Member691's Avatar
    Please tell me what "AOD" is. Thanks.
    09-28-2018 02:58 PM
  3. Gimelie's Avatar
    Always on display
    09-28-2018 03:06 PM
  4. note1note9's Avatar
    Try contacting samsung live chat service?
    09-28-2018 03:24 PM
  5. mlblack16's Avatar
    I'm not completely certain what you're asking, but I can tell you a couple things:
    The path in settings to get you to AOD would be Settings > Lockscreen & Security > Clock & Face Widgets > Clock Style
    I have never used the option in AOD to assign an image or .gif but usually, to delete items in Android OS, you tap and hold (aka long press) an item and the option to either slide to a trash can, delete, etc will become obvious. After deleting, I'm guessing the + sign will return, indicating you can add an image, . gif, etc.
    09-28-2018 08:39 PM
  6. Member691's Avatar
    Always on display
    Thanks
    09-28-2018 08:41 PM
  1. Does the 2 have the same issues with lag as the 2 XL?
    By whitenack in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 10-29-2018, 03:25 PM
  2. Google assistant commands issues
    By DARK Vader777 in forum Samsung Galaxy Note 9
    Last Post: 09-27-2018, 11:37 AM
  3. Issue with my child's phone
    Last Post: 09-26-2018, 02:10 PM
  4. Pixel 2 wifi connection issue
    By Nnelg77 in forum Google Pixel 2 & Pixel 2 XL
    Last Post: 09-26-2018, 12:40 PM
  5. Lasy swipe annoyance issue
    Last Post: 09-25-2018, 05:03 PM
