Upgrading your router, since that's your limiting point, ac wifi should go up to 1.3gbps, but if your provider is only giving you gigabit speed, that's the most you can get, except for phone to something else on the LAN. But what you get for downloads - that depends on the server you're downloading from and your path to it. It the download gets from the server to your provider at 5mbps, the individual packets will get to you at 1gbps, but there will be huge holes of silence between packets. Np matter what you do, your download speed will be 5mbps. A download is as fast as its slowest portion.
09-28-2018 08:59 PM
