Poor Battery Life?
Bruce_205
Active member
Jun 26, 2015
31
I think my S9 (bought in June) is going through power too fast. Its been off the charger for 1 hour 13 minutes with no action (screen off, no calls, etc) and I am down to 95% according to GSAM battery monitor.
The other day I went to a car show outdoors. I started with 100% and the phone shut off with 5% or less after less than 3 hours. The only app being used was the camera (Open Camera app) and gallery. And of course the screen was mostly on. Is 2.5 hours normal in that scenario?
I notice that even when I don't take pictures it still doesn't seem to be as good as my old LG G4 and its supposed to have such a great processor and more efficient.
Is this normal?
Hermes Hidayat
2,617
38
Is this normal?
How is your phone signal?
anon(5719825)
Retired Moderator
Feb 21, 2013
3,797
One thing you can change is your location accuracy. Go to settings, connection. Under Location, select battery saving.
My AT&T Note 9 has a habit of changing the setting back to high accuracy and I can always tell when it's done this.
methodman89
4,139
295
83
Open Settings, Device maintenance, Select Battery, then select Battery Usage. Look at the list and see what is using the juice. Something is amiss for sure.
Hermes Hidayat
2,617
38
From my personal experience. High doesnt drain much juice. But Bluetooth Scanning does. Its located at Improve Accuracy.
methodman89
4,139
295
83
Did I hit the trifecta? My S7, S8 Active and S9 plus all give me at least 36 hours.
To be fair, so does my apple.
It's all about configuration after purchase and not installing garbage which you allow to turn on GPS, BT, and WiFi radio.
Bruce_205
Active member
Jun 26, 2015
31
Ok, I just looked at "improve accuracy" and Bluetooth was checked. I turned it off. Wifi scanning is on though along with high accuracy. How does wifi improve location accuracy?
Under apps I can't see anymore what was active yesterday when I had the huge battery drain but today it does not look too bad. I am 6 hours 19 min into my battery use for today and at 67% with the most use being screen and Chrome. The bloat ware apps barely register, like 0.01%.
I just noticed I am not using wifi here at work today. Maybe wifi sucks a lot of power?
Hermes Hidayat
2,617
38
Having Wifi Scanning on is no harm. As some apps require it on to get better accuracy such as Google Maps. But if you do not use Google Maps you can turn it off too.
And if im not wrong.Wifi Scanning is like background searching of wifi spots to help assist location.
Hermes Hidayat
2,617
38
My biggest Garbage is Instagram... Instagram has crazy background stuff and it takes a lot of juice. Turning off background activity however makes Instagram less hungry for juice.
Bruce_205
Active member
Jun 26, 2015
31
I have "Keep mobile data turned on" selected under Developer Options. I wish Samsung would not have removed the shortcut icon mobile data switch so I could quickly turn it on if I need it. When I first got the phone I read how to get it back, there was something about editing an xml file that has the shortcuts, but I forgot how. The shortcut got deleted probably when I got a system update.
methodman89
4,139
295
83
Go to Settings, Connections, Data Usage, and you can toggle it on or off there. 3 clicks.
Hermes Hidayat
2,617
38
Erm... There's a shortcut
L0n3N1nja
3,629
4
That's the shortcut I was talking about. I do not have that on my S9. How do I get it back?
When you pull down to see all of the button shortcuts like in the screen shot above, tap the 3 dots in the top right and adjust your button layout. You can pick and choose which short cuts you want, mobile data might just be disabled.
Bruce_205
Active member
Jun 26, 2015
31
I got it. It was not a simple button order. Apparently on the AT&T version they actually leave it out. I got it back by typing a command in the adb shell. So now I'm going to switch off "keep mobile data on".
For today I'm at 48% remain after 11 hours including 2.5 hours screen on time.
Hermes Hidayat
2,617
38
Wow... A&T locked the option?
kerokekerol
