10-20-2018 07:54 PM
30 12
tools
  1. Bruce_205's Avatar
    I think my S9 (bought in June) is going through power too fast. Its been off the charger for 1 hour 13 minutes with no action (screen off, no calls, etc) and I am down to 95% according to GSAM battery monitor.
    The other day I went to a car show outdoors. I started with 100% and the phone shut off with 5% or less after less than 3 hours. The only app being used was the camera (Open Camera app) and gallery. And of course the screen was mostly on. Is 2.5 hours normal in that scenario?
    I notice that even when I don't take pictures it still doesn't seem to be as good as my old LG G4 and its supposed to have such a great processor and more efficient.
    Is this normal?
    10-14-2018 05:10 PM
  2. Hermes Hidayat's Avatar
    Is this normal?
    How is your phone signal?
    10-14-2018 06:40 PM
  3. Bruce_205's Avatar
    The signal is normal. No problems.
    10-14-2018 07:09 PM
  4. anon(5719825)'s Avatar
    One thing you can change is your location accuracy. Go to settings, connection. Under Location, select battery saving.
    My AT&T Note 9 has a habit of changing the setting back to high accuracy and I can always tell when it's done this.
    10-14-2018 08:07 PM
  5. methodman89's Avatar
    Open Settings, Device maintenance, Select Battery, then select Battery Usage. Look at the list and see what is using the juice. Something is amiss for sure.
    10-14-2018 09:03 PM
  6. Hermes Hidayat's Avatar
    From my personal experience. High doesnt drain much juice. But Bluetooth Scanning does. Its located at Improve Accuracy.
    Attached Thumbnails Poor Battery Life?-screenshot_20181015-080659_settings.jpg
    methodman89 likes this.
    10-14-2018 09:08 PM
  7. Hermes Hidayat's Avatar
    Turn off Bluetooth Scanning for Locations.
    10-14-2018 09:09 PM
  8. methodman89's Avatar
    Did I hit the trifecta? My S7, S8 Active and S9 plus all give me at least 36 hours.
    To be fair, so does my apple.
    It's all about configuration after purchase and not installing garbage which you allow to turn on GPS, BT, and WiFi radio.
    10-14-2018 09:41 PM
  9. Bruce_205's Avatar
    Ok, I just looked at "improve accuracy" and Bluetooth was checked. I turned it off. Wifi scanning is on though along with high accuracy. How does wifi improve location accuracy?
    Under apps I can't see anymore what was active yesterday when I had the huge battery drain but today it does not look too bad. I am 6 hours 19 min into my battery use for today and at 67% with the most use being screen and Chrome. The bloat ware apps barely register, like 0.01%.
    I just noticed I am not using wifi here at work today. Maybe wifi sucks a lot of power?
    10-14-2018 09:46 PM
  10. Hermes Hidayat's Avatar
    Having Wifi Scanning on is no harm. As some apps require it on to get better accuracy such as Google Maps. But if you do not use Google Maps you can turn it off too.
    And if im not wrong.Wifi Scanning is like background searching of wifi spots to help assist location.
    10-14-2018 10:26 PM
  11. Hermes Hidayat's Avatar
    My biggest Garbage is Instagram... Instagram has crazy background stuff and it takes a lot of juice. Turning off background activity however makes Instagram less hungry for juice.
    10-14-2018 10:30 PM
  12. Bruce_205's Avatar
    I have "Keep mobile data turned on" selected under Developer Options. I wish Samsung would not have removed the shortcut icon mobile data switch so I could quickly turn it on if I need it. When I first got the phone I read how to get it back, there was something about editing an xml file that has the shortcuts, but I forgot how. The shortcut got deleted probably when I got a system update.
    10-14-2018 11:14 PM
  13. methodman89's Avatar
    Go to Settings, Connections, Data Usage, and you can toggle it on or off there. 3 clicks.
    10-14-2018 11:17 PM
  14. Hermes Hidayat's Avatar
    Erm... There's a shortcut
    Attached Thumbnails Poor Battery Life?-screenshot_20181015-103950_nova-launcher.jpg   Poor Battery Life?-screenshot_20181015-103956_nova-launcher.jpg   Poor Battery Life?-20181015_112355.jpg
    10-14-2018 11:40 PM
  15. Bruce_205's Avatar
    That's the shortcut I was talking about. I do not have that on my S9. How do I get it back?
    10-15-2018 02:15 AM
  16. L0n3N1nja's Avatar
    When you pull down to see all of the button shortcuts like in the screen shot above, tap the 3 dots in the top right and adjust your button layout. You can pick and choose which short cuts you want, mobile data might just be disabled.
    10-15-2018 02:24 AM
  17. Hermes Hidayat's Avatar
    Attached Thumbnails Poor Battery Life?-20181015_133751.jpg   Poor Battery Life?-20181015_133804.jpg   Poor Battery Life?-screenshot_20181015-133709_nova-launcher.jpg
    10-15-2018 02:39 AM
  18. Bruce_205's Avatar
    I got it. It was not a simple button order. Apparently on the AT&T version they actually leave it out. I got it back by typing a command in the adb shell. So now I'm going to switch off "keep mobile data on".
    For today I'm at 48% remain after 11 hours including 2.5 hours screen on time.
    10-15-2018 02:52 AM
  19. Hermes Hidayat's Avatar
    Wow... A&T locked the option?
    10-15-2018 02:58 AM
  20. methodman89's Avatar
    Don't have it on tmobile either.
    10-15-2018 04:06 AM
  21. Hermes Hidayat's Avatar
    Phew...
    10-15-2018 04:23 AM
  22. Bruce_205's Avatar
    Sure...they don't want to make it easy for us to turn off data...so we keep data on and run over our limit = more $$ for them! Thankfully, its part of the Android o/s so we can modify it and get it back.
    10-15-2018 04:43 AM
  23. Hermes Hidayat's Avatar
    Im sorry to hear that. In Indonesia everything is unlocked...
    10-15-2018 05:03 AM
  24. Lecrae116's Avatar
    Sprint has the mobile data shortcut.
    10-16-2018 09:27 PM
  25. Lecrae116's Avatar
    How can you figure wifi scanning doesn't drain battery? Also does anyone know if calling plus drains alot of battery.
    10-16-2018 09:33 PM
30 12
  1. Way to check battery health?
    By I_didnt_do_it in forum Samsung Galaxy S7
    Last Post: 10-29-2018, 04:49 PM
  2. Yet another battery life question
    By tmoleary in forum Samsung Galaxy S5 Active
    Last Post: 10-15-2018, 06:18 PM
  3. Are replacing the battery expensive?
    Last Post: 10-14-2018, 01:57 PM
  4. Battery never charges to 100%
    Last Post: 10-14-2018, 10:53 AM
  5. Replies: 1
    Last Post: 10-13-2018, 08:23 PM
