Would that I could. I participated in the Oreo beta as well, and enjoyed it. Still on the S8 though.
Oh, it's something I think about. Especially after the Oreo beta. Loved the experience. If I wasn't eyeballing the S10 or even the OnePlus 6T, I'd pick up an S9 just to join. The new OS leaks look great.Got the S9+ for $289 through the trade in program. Honestly not a huge change from my S8+. Anyway, I'm a sucker for betas, so looking forward to it.
How do I sign up?
I heard it was only for Verizon?I downloaded the pie beta early release, I'm loving it except the icons ...you can find the link in XDA forums if u want to try . if you have hard time installing the zip update through computer just download to the SD card and your good to go
I have it installed on my s9+. It's running very smooth with no real hiccups. I'm trying to get my wireless Android Auto to work on my pioneer W4400nex radio.
It surely worth using it daily. I like the sweetie function that replaces the navigation bar.
Does installing it through the computer or SD card lose any data on your phone?I downloaded the pie beta early release, I'm loving it except the icons ...you can find the link in XDA forums if u want to try . if you have hard time installing the zip update through computer just download to the SD card and your good to go
