1. Indecisi0n's Avatar
    Whats the max wifi these phones are capable of? I only ask because I have gigabyte speeds and my phone doesn't get near that. Now I understand it won't get a gig but was curious. Seems most times it floats around the 200mbps area.
    11-10-2018 09:04 AM
  2. vader4633's Avatar
    If your router has separate 2.4 and 5ghz bands, you can name each different and connect to the 5 ghz band to get the fastest speed. Some routers will mix both bands under one network name and decide what speed to deliver for you.
    11-10-2018 11:34 AM
  3. Indecisi0n's Avatar
    I am on 5G
    11-10-2018 08:56 PM
  4. claykin's Avatar
    If you have a Wave 2 AC Router with 2x2 80Mhz support you can get 400Mb/s one way from an S9. This assume you're using 5Ghz and have a strong signal. 80Mhz will fall back to a a slower speed if signal is weaker than about -60db. Basically you'll need to be in same room or nearby the router to keep an 80Mhz connection going.
    11-10-2018 08:58 PM
  5. Indecisi0n's Avatar
    If I stand under the AP I am getting 315mbps. Ill have to relocate the AP.
    11-10-2018 11:47 PM
  6. claykin's Avatar
    What make/model router?
    11-11-2018 07:32 AM
  7. Indecisi0n's Avatar
    Modem is Verizon gigabyte Motorola modem. The AP is UniFi AP Pro.
    11-11-2018 10:49 AM
  8. claykin's Avatar
    AP Pro or AC Pro?
    11-11-2018 03:48 PM
  9. Indecisi0n's Avatar
    AP Pro or AC Pro?
    Ubiquiti Networks UAP-AC-PRO
    11-12-2018 10:01 AM
  10. claykin's Avatar
    You should be able to link up at 867Mb/s. Since that's both ways, you'll get roughly half that in real world when downloading or uploading. Figure slightly less than 400Mb/s each way.
    You can try to upgrade your AC Pro firmware and see if that helps. Also do the following in your controller:
    Upgrade to 5.9.32 or higher.
    Enable advanced features
    Don't use airtime fairness or band steering in AC Pro device settings. To force 5Ghz set a separate SSID and assign only 5Ghz radio.
    Make sure 5Ghz radio is set to 80Mhz
    For WiFi networks use WPA2 AES only.
    Turn off connectivity monitor.
    Disable unscheduled auto power save delivery
    Do you have another router or using the isp modem as a router?
    FYI, your AC Pro is capable of 1300Mb/s link with about 600Mb/s each way. Your phone isn't.
    11-12-2018 07:22 PM
  1. Replies: 1
    Last Post: 11-10-2018, 02:46 AM
  2. Why is my samsung s3 version 4.3 cannot connect wifi in far ?
    Last Post: 11-10-2018, 02:38 AM
  3. Galaxy S5 g900t wifi keeps dropping after usb daughter board replacement
    Last Post: 11-09-2018, 09:13 PM
  4. Getting email notifications on the home screen with my S9+
    Last Post: 11-09-2018, 07:17 PM
  5. How can I make my Huawei P9 stop connecting to open WIFI networks?
    By Android Central Question in forum Huawei P9 & P9 Plus
    Last Post: 11-09-2018, 07:11 PM
