1. jddimov's Avatar
    So... This might be the most ridiculous question ever asked on this forum, but i will post it anyway. I bought S9 Plus a couple of months ago, but recently I noticed something that is driving me crazy. I feel that the edges of the screen are raised and the middle (center) part of the display is sunken a little bit. It is noticable when I run my finger from one edge of the screen to the other. Is just my device unit flawed or are they all build the same way? Has anyone else noticed this? The attached file shows a profile of the front glass. Pls, excuse my drawing skills ))
    11-12-2018 12:59 PM
  2. missy8787's Avatar
    I noticed that on mine and I just got it about a week ago I thought that was the design
    11-12-2018 05:20 PM
  3. lucianus_luciferus's Avatar
    it is probably an optical illusion caused by the curved edges.
    if you look at it from the left or right side you will see it is perfectly flat
    mary beth hale likes this.
    11-12-2018 06:13 PM
  4. mary beth hale's Avatar
    Yes
    11-12-2018 07:06 PM
  5. jddimov's Avatar
    Or it's just my OCD Either way it's driving me insane!
    11-13-2018 09:49 AM
  6. rudyn43's Avatar
    I bought my S9+ a couple of months ago also and just checked it. It is a optical illusion as far as I can tell. Looking from the side it is flat and from top to bottom it looks curved. However it feels flat to me.
    jddimov likes this.
    11-13-2018 10:46 AM
  7. DARK Vader777's Avatar
    Just received my S9 plus I ordered for my grandson. Very very nice. I have the
    note 9 and Op5t and the S9 plus is second to none. My grandson is so happy.
    11-14-2018 12:31 PM
  1. Backing up Texts from Galaxy S 7 Edge
    By Android Central Question in forum Samsung Galaxy S7 edge
    Last Post: 11-20-2018, 06:07 PM
  2. Why does my Samsung Galaxy Tab4 10.1 display a Low Internal Memory Warning
    By Android Central Question in forum Samsung Galaxy Tab4 10.1
    Last Post: 11-13-2018, 10:21 AM
  3. S8 plus goes blank and after i reboot goes blank again
    Last Post: 11-12-2018, 06:56 PM
  4. "Primary Mail Only" Gmail notifications on Gear Sport from Samsung Phone
    By Android Central Question in forum Samsung Gear Sport
    Last Post: 11-12-2018, 12:04 PM
