1. subiedude14's Avatar
    hey guys, Im having some troubles connecting my phone via usb to my aftermarket pioneer head unit in my car. I usually just use bluetooth but i want a higher quality audio. This worked perfectly with my old GS6+, so i am sure that it is not an issue with my stereo, but with my phone. Except for one thing... once in a while when i plug it in it will start playing samsung music, but once i try to play spotify and make my phone make any sound (ringtones, game music), the samsung music stops and the sound plays through my phone speakers. a while back i researched it but couldn't find anything. Any suggestions?
    11-13-2018 08:12 PM
  2. claykin's Avatar
    First try a different USB cable. Such as the one that came with your phone.
    11-13-2018 09:52 PM
  3. subiedude14's Avatar
    tried it. its something to do with the phone
    11-13-2018 09:57 PM
  4. mpcook's Avatar
    Mine only works 100% when I start the car with the phone already connected via cable. If I plug the cable in after the car/HU are running, only successful some of the time.
    11-14-2018 08:13 AM
  5. Isidoro Castell's Avatar
    Mine also works well
    11-14-2018 09:04 AM
  6. claykin's Avatar
    Or something with the head unit. Check OEM for firmware update for stereo. If it's an older model you might be out of luck.
    11-14-2018 10:41 AM
  1. Replies: 7
    Last Post: 03-24-2019, 07:04 AM
  2. Here GPS over my car speakers
    Last Post: 11-14-2018, 11:52 AM
  3. Transferring to a tablet from a phone?
    Last Post: 11-14-2018, 11:40 AM
  4. I have a pattern password and I forgot it and I need to know it
    By Marissa Beach in forum Samsung Galaxy S5
    Last Post: 11-13-2018, 09:55 PM
  5. Here GPS over my car speakers
    Last Post: 11-13-2018, 04:27 PM
