1. Tim98TA's Avatar
    On my old HTC10 I was able to put the WiFi, Bluetooth and GPS shortcuts on my Home screen. I don't see that option with the S9. I only see being able to put Widgets on there.
    Anybody found a way to do that?
    11-20-2018 06:00 AM
  2. bbgpsuser's Avatar
    If you swipe down from the top of the screen, you can directly open any of those by holding your finger on the icon.
    11-20-2018 07:34 AM
  3. Javier P's Avatar
    We discussed a similar issue here.
    https://forums.androidcentral.com/sh...d.php?t=922619
    11-20-2018 07:38 AM
  4. Velenoso's Avatar
    They're called "quick settings", you might want to find a video to check out their usefulness.
    11-20-2018 08:41 AM
  1. My game apps have dissapered and i can't find them
    Last Post: 11-20-2018, 05:05 AM
  2. Replies: 1
    Last Post: 11-20-2018, 05:01 AM
  3. Problem with Guest Wifi Connection
    By JACKREACHER193 in forum Samsung Galaxy Note 9
    Last Post: 11-20-2018, 04:38 AM
  4. Problem with Guest Wifi Connection
    Last Post: 11-20-2018, 04:05 AM
  5. How do I get my original home screens back on my Android phone.
    Last Post: 11-20-2018, 12:25 AM
