    I have had my s9 for 4 weeks now and had trouble getting it to charge I have to take the plug out a number if times fornitbto charge I've even got new chargers for this is this a common problem
    12-26-2018 03:23 PM
  2. belodion's Avatar
    I don't know that it's common, though I doubt that it is given reasonable treatment of the phone, but let's ask the S9 guys by moving the thread there.
    I'm guessing you may have a damaged or faulty charging port.
    12-26-2018 04:09 PM
  3. crossdeath's Avatar
    It's definitely not common. I have mine since launch and it makes the same 'click' when I plug it in as it did on day one. Plus, it charges normally. You should first clean the charging port of any lint and everything else that's inside. If it's still not working, try bringing it to a repair center.
    belodion likes this.
    12-30-2018 05:52 AM
  4. B. Diddy's Avatar
    The OP didn't mention if the new chargers work fine, or if they also have the same problem. If they work fine, then it's probably just a bad charging cable and/or plug.
    01-01-2019 04:34 PM
  1. Troubleshooting .apk error "App Not Installed"
    Last Post: 12-27-2018, 10:26 PM
  2. Fantasy charger not working on my s8
    Last Post: 12-26-2018, 02:36 PM
  3. what is the solutions to my infinix x551 auto rotate not working
    Last Post: 12-26-2018, 02:04 PM
  4. Link opened with samsung watch always opens when i unlock the screen (Samsung Galaxy S9)
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 12-26-2018, 10:36 AM
  5. Replies: 0
