    I just bought my galaxy s9 plus in the beginning of this month, the phones great and I love everything about it but the call quality is bugging me.
    It sounds distorted on my end and the faint noises through the call sound like I'm listening to a 140p video. This wasn't just with the external speakers but it's the same even with earphones on no matter the type, so it might be a software issue.
    I noticed it straight when I used Skype the first time I got the phone and it was completely the same when I normally call someone. It even sounds distorted on some media that I play too. I tried restarting my phone, wiping the cache, nothing changed. Is there a fix to this or am I the only one?
    12-29-2018 12:48 PM
  2. BerryBubbles's Avatar
    Originally, my US T-Mobile s9+ did not have desirable call quality. It sounded like I & the other party were talking through tin cans. Eventually, after software updates, the problem was corrected. In my case, I believe the October update made the biggest difference. So if you haven't already, you might check to see if you have all your updates installed.
    Best of luck! It's a great phone.
    pontiac005 likes this.
    12-29-2018 07:14 PM
  1. Why does the battery usage dont show the full results on s9+?
    By noel bisha45 in forum Samsung Galaxy S9 & S9+
    Last Post: 01-02-2019, 06:55 PM
  2. Some (but not all) apps crash when they are opened (Samsung Galaxy A3)
    Last Post: 12-30-2018, 09:58 AM
  3. Samsung Galaxy S7 will not detect OTG
    By Android Central Question in forum Samsung Galaxy S7
    Last Post: 12-29-2018, 02:05 PM
  4. How does the s8 plus screen width compare to the note edge?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 12-29-2018, 12:04 PM
  5. Replies: 0
    Last Post: 12-29-2018, 11:35 AM
