    Hi recently my note 9 has lost the auto,pro and panoramic camera feature. I cannot take any photos with the rear camera. The selfie options are appearing and front camera is working. The rear camera is working on snapchat
    12-29-2018 03:30 PM
  2. L0n3N1nja's Avatar
    If the rear camera works on snap it shouldn't be a hardware issue which is good.
    First step would be to clear the camera app cache.
    Open settings>apps>camera>storage>clear cache.
    12-29-2018 05:26 PM
  3. krisqz's Avatar
    You mean you can't switch to rear camera? Swipe up in vertical position doesn't work?
    12-29-2018 08:10 PM
  1. Enhanced features
    Last Post: 12-30-2018, 10:57 AM
  2. Huawei Mediapad M5 8.4": measured overall thickness including the camera?
    By Android Central Question in forum Huawei MediaPad M5
    Last Post: 12-29-2018, 06:25 PM
  3. Swap back and recents keys
    Last Post: 12-29-2018, 05:26 PM
  4. How does the s8 plus screen width compare to the note edge?
    By Android Central Question in forum Samsung Galaxy S8 & S8+
    Last Post: 12-29-2018, 01:04 PM
  5. How does the s8 plus screen width compare to the note edge?
