1. stbiggles's Avatar
    I have been using
    BP Lab for months but suddenly it can't find the BP sensor on my S9. Anyideas/fixes?
    01-01-2019 08:49 AM
  2. jgreg02's Avatar
    Same here. I emailed both the developer and the researcher at UCSF. I uninstalled and reinstalled the app and no change. Should hear back in a day or two.
    01-01-2019 01:39 PM
  3. Dmitriy Fingerman's Avatar
    I had the same issue and found that it is related to the current date on the phone. If the date is past December 31th 2018, the app doesn't work. Change system date manually to prior to that date and the app works again! I hope this limitation is in the "My BP Lab" app and not in OS itself...
    01-01-2019 02:41 PM
  4. jgreg02's Avatar
    Google Play has an update today for the app. that fixes the problem.
    01-02-2019 09:59 PM
  5. Martin Bertram's Avatar
    Just installed the update Version 1.0.6 (76), but it still doesn't work.
    01-08-2019 10:22 AM
  6. Dmitriy Fingerman's Avatar
    Version 1.0.6 had the date issue. The version that works is 1.1.15
    01-08-2019 10:26 AM
  7. Martin Bertram's Avatar
    OK got the right version now from https://apk.plus/download/org.sagebi...d64b2119a49f6/
    Version 1.1.5 fixes the problem. Thank You Dmitriy
    Do not use this link: https://apkgk.com/org.sagebionetwork...ch.bp/download
    it says version 1.1.5 but if you click download latest version, you'll get 1.0.6
    01-08-2019 10:51 AM
  8. jgreg02's Avatar
    download from Google play. it has the working version.
    01-08-2019 09:51 PM
  1. One no is being automatically rejected I want to not reject
    Last Post: 01-01-2019, 01:02 PM
  2. how do i fix the problem "internet may not be available " on my Galaxy J 5 pro
    Last Post: 01-01-2019, 12:59 PM
  3. S7 Edge loads some but not all contacts to bluetooth in car
    By Rob666 in forum General Help and How To
    Last Post: 01-01-2019, 12:50 PM
  4. Replies: 1
    Last Post: 01-01-2019, 02:34 AM
  5. Replies: 2
    Last Post: 01-01-2019, 02:00 AM
