    I bought the Samsung Galaxy s9+ when it first came out. Ever since, I've had a yellow tint issue with it. When I unlock my phone, it will be yellow in a corner then as soon as I touch the screen, the whole thing turns yellow. When the system updates come out, it's fixed until my battery dies or the phone is powered off. As soon as I turn it back on, then yellow tint crap happens again.
    I have tried restarting, booting into safe mode, wipeing the catches, turning blue light filter on and off, turning auto brightness off, messing with the colors.... nothing ive tried works except for a system update which is really inconvenient when there isn't a new update available. What else can I do?
    01-01-2019 07:33 PM
  2. chanchan05's Avatar
    When you say messing with colors, did that include changing the display mode? I know basic mode has a yellowish tint to it.
    01-01-2019 07:45 PM
  3. aliface2008's Avatar
    I did try that, it didn't help. The weird thing to me is that the system update fixes it until the phone powers off or I reset it.
    01-02-2019 07:29 AM
  4. belodion's Avatar
    I'll move this to S9 for comments from other users.
    01-02-2019 07:35 AM
  5. randynjaimie's Avatar
    From the swipe down settings, is your "Blue Light Filter" turned on? If so, turn it off and the yellowish hue will go away. It is a great feature when reading in low light, but really annoying for just about everything else
    01-05-2019 01:44 PM
  1. Replies: 5
    Last Post: 10-21-2019, 11:25 PM
  2. Flashed US T-Mobile Galaxy s7 SM-G930T to the latest Verizon Firmware. Wifi will not stay connected.
    By Android Central Question in forum Samsung Galaxy S7 Rooting, ROMs, & Hacks
    Last Post: 08-30-2019, 11:20 AM
  3. Can you upgrade the front camera on a Galaxy tab S2?
    Last Post: 01-02-2019, 01:26 AM
  4. Replies: 1
    Last Post: 01-01-2019, 04:22 PM
  5. Galaxy S9 Micro SD Card
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 01-01-2019, 02:02 PM
