1. jenni122701's Avatar
    After having this phone for many, many months now and reading all about the notifications and what to check and all, doing and checking the edge lighting stuff, and even trying the glimpse app to no avail, what is with not being able to SEE notifications with this phone?! I just want my screen to light up when I get a text/msg from my msg apps, why can this not happen? I've tried EVERYTHING. Is there really no way to have this happen with the S9? Is it just MY phone? I love the S9 but I just can't stand this.
    Sn0man likes this.
    01-02-2019 08:28 PM
  2. scottbeamer's Avatar
    See them where?
    01-02-2019 10:45 PM
  3. sulla1965's Avatar
    I don't understand what your asking. You want the screen to "light up" Did you enable the notification light. Have you enabled edge lighting? Try light manager for notifications. ???
    scottbeamer likes this.
    01-02-2019 11:10 PM
  4. martyn30162's Avatar
    try turning off caller id and spam protection in settings
    01-03-2019 06:12 AM
  5. jenni122701's Avatar
    Yes, I want the screen to light up and show I have a msg when I get one, instead of just staying dark. I have enabled the notifications and edge lighting. The little, tiny red light will light up, but its easily missed, I'm talking about the screen itself lighting up, something noticeable.
    Sn0man likes this.
    01-03-2019 08:47 PM
  6. cdigga101's Avatar
    Install Light Manager from platy store. Go to advanced settings, wake screen, then select whichever app u want notifications from
    01-04-2019 03:14 AM
  7. jenni122701's Avatar
    Thanks, will def give this a try. Appreciate it.
    01-04-2019 08:10 AM
  8. methodman89's Avatar
    Do your settings look like this?
    01-04-2019 11:10 AM
  9. jenni122701's Avatar
    Yes.
    01-04-2019 04:43 PM
  10. methodman89's Avatar
    Did you install an edge controlling app from the playstore?
    01-04-2019 04:48 PM
  11. jenni122701's Avatar
    No, but I figured out the issue. Why the screen wasn't lighting up when I would get a msg. I was not using the default msg app, but another messages app. Went to the default one and it works. So I guess that was the issue. Wow. All this time I was using the wrong Messages app. Thank you!
    01-04-2019 04:54 PM
  12. methodman89's Avatar
    I use Textra and have no notification problems. You may like its custom notification settings better than the stock one.
    jenni122701 and Mojave like this.
    01-04-2019 05:06 PM
  13. SpookDroid's Avatar
    Was about to suggest that haha Yeah, not all apps (THANK JEBUS! Yes, I HATE that the screen lights up with texts) support that, and some (like Textra or Pulse) allow you to choose how you want it to behave.
    For Edge Lighting to work (if you want something more 'subtle' and you want to keep using your current app) you need to set the notification to be a Pop Up on screen (set to 'URGENT' like in methodman's screenshot) or it won't detect it.
    jenni122701 likes this.
    01-04-2019 05:09 PM
  14. jenni122701's Avatar
    I appreciate all the help, def learned a couple things I still didn't know. I am just REALLY happy now that my screen lights up with text alerts. That's a big help for me. I had my headset on a LOT and don't hear the notification, but if the screen lights up, I can pretty much catch it. That was bugging the crap out of me. LOL
    01-05-2019 03:58 PM
  1. Editing S9+ Slow Motion Video?
    By roweder in forum Samsung Galaxy S9 & S9+
    Last Post: 05-01-2019, 11:18 AM
  2. Person icon in notification bar that quickly disappears
    Last Post: 01-14-2019, 01:28 PM
  3. Unable to transfer video from my Samsung Galaxy S9 to my PC.
    By Marino Steele in forum Samsung Galaxy S9 & S9+
    Last Post: 01-04-2019, 06:52 PM
  4. Android Pie icon issue: notification icon are cutting in half
    By Lucas Pinheiro in forum Ask a Question
    Last Post: 01-03-2019, 10:46 AM
  5. Unable to transfer video from my Samsung Galaxy S9 to my PC.
    By Marino Steele in forum Ask a Question
    Last Post: 01-02-2019, 05:51 PM
