Save big + get 3 months free! Sign up for ExpressVPN today
    I have recently updated top Android Pie based One UI on my samsung s9+ and noticed that i can no longer use split screen for multiple apps. Has this feature been removed from One UI bcz it is available on other phones running Android Pie.
    01-06-2019 12:16 AM
  2. methodman89's Avatar
    After you updated, have you made sure it's enabled in your settings?
    01-06-2019 05:30 AM
  3. kptsalami's Avatar
    You probably have figured out by now, but if not, you go to your recent apps and then tap on the icon on top of the app to enable split screen
    Jasest likes this.
    02-02-2019 09:02 AM
  4. Jasest's Avatar
    Thank you ktpSalami!
    Thought this was another lost feature and disappointed because I like to watch sport and browse simultaneously.
    Life saver, cheers
    02-11-2019 03:29 PM
  5. Ed Ahorlu's Avatar
    Mine keeps disappearing.
    It's there one day then can't find it the next. Don't know what's the problem.
    Attached Thumbnails How does one enable split screen in samsung s9+ with One UI-59054.jpg
    02-18-2019 06:02 AM
  6. Ed Ahorlu's Avatar
    Now it's back
    Attached Thumbnails How does one enable split screen in samsung s9+ with One UI-59056.jpg
    02-18-2019 06:12 AM
  7. kimpop's Avatar
    I have a Sumsung S9 And just like you I was able to use the split screen option but ever since I did the update I can't find the option to do the split screen.. How do I go about doing the split screen option? And also how do I go about doing the multi screen Option?
    02-18-2019 10:00 AM
  1. Question screen saver
    By mustang7757 in forum Google Pixel 3 & Pixel 3 XL
    Last Post: 01-07-2019, 06:38 PM
  2. Replies: 1
    Last Post: 01-06-2019, 12:49 AM
  3. How would i factory
    Last Post: 01-06-2019, 12:48 AM
  4. If Nokia 6.1 does not connect to Nokia pc Suite then whats the alternative?
    Last Post: 01-06-2019, 12:43 AM
  5. Why does Find my device app stays on?
    Last Post: 01-06-2019, 12:33 AM
