1. Emanuel Levy's Avatar
    I know on the S9+ you can connect two Bluetooth devices and stream the same audio to both at the same time but I want to do something different
    I want all audio except Waze (and phone calls) to go to one Bluetooth Device (Car Audio Profile) and Waze or Waze and Phone calls to go to a Bluetooth earpiece.
    I can't find a way to do it.
    Right now I am using a cable from the headphone jack to line in on my car to play audo but the sound quality is dimished and I have it set for Waze to go out over Bluettoth which goes to my earbud.
    01-06-2019 04:58 AM
  2. krisqz's Avatar
    Not sure if it'll help but there is an app on Samsung Store called Sound Assistant. It's an official app from Samsung. Has few extra options for sound management on S9.
    01-06-2019 05:55 AM
  3. Adam Frix's Avatar
    I don't remember the details, but you have the Separate App Sound setting. Find it, and check it out.
    As for the cable from the headphone jack into your car audio, that's not where the diminished sound quality comes from. Bluetooth is where the diminished sound quality comes from.
    01-06-2019 08:04 AM
  1. I would like to know if I can delete the Android "UPSELL" app without any issues?
    Last Post: 01-07-2019, 11:42 AM
  2. Replies: 4
    Last Post: 01-06-2019, 05:37 PM
  3. where can i go to download an coustom ios to put on my phone
    Last Post: 01-06-2019, 05:23 AM
  4. How to get stock Android, while I have the Oppo Color OS.
    By ShivananKaur in forum Ask a Question
    Last Post: 01-06-2019, 01:09 AM
  5. Replies: 1
    Last Post: 01-06-2019, 12:55 AM
