1. Trees's Avatar
    This evening a Google Play App Update notification appeared which informed me an update for Verizon Call Filter is available. Since I did not recognize that app, I checked to see if it showed up in Settings\Apps, and Verizon Call Filter is not listed.
    I toggled on the "Show system apps " view, and did not see Verizon Call Filter. I don't know if any of the com.verizon.* or com.vzw System Apps are related, nor the vzw_msdc_api, or VZW_Multicast_MW have any potential correlation to Verizon Call Filter. I am also assuming that Verizon Location Agent is unrelated.
    Anyone else get the Google Play App Update notification, or see Verizon Call Filter in your S9/S9+ (Verizon version)?
    I see in the Update description "Whats New" section that a prior app/product was renamed to Verizon Call Filter. So what is/was the prior app/products name?
    01-09-2019 09:49 PM
  2. Wolfie410's Avatar
    Caller Name ID.
    I have mine disabled, but when I went into the play store "Caller Name ID" isn't listed, but "Verizon Call Filter" is there and disabled.
    Trees likes this.
    01-10-2019 07:23 AM
  3. Trees's Avatar
    Good to know, mystery solved. I looked closely at the Caller Name ID app icon in Settings/Apps and now see the tiny red Verizon check mark. Totally missed that before.
    01-11-2019 05:59 AM
  1. Bluetooth switches from media audio to call audio (Note 9)
    Last Post: 03-08-2019, 09:12 AM
  2. Video apps crashing on Galaxy Tab E (Verizon)
    Last Post: 01-10-2019, 10:22 AM
  3. LG V40 Tone During Bluetooth Call
    Last Post: 01-09-2019, 02:51 PM
  4. Replies: 2
    Last Post: 01-09-2019, 02:44 PM
  5. Which version of LG V30 will work on both Verizon and Telus-Canada?
    Last Post: 01-09-2019, 12:57 PM
