A
Android Central Question
I would like to know if there's a way to add NCAA men's basketball and NCAA football teams to the apps edge "sport" part. I see pro leagues but not college
That's dependent on the maker of the app of he included sources for NCAA. You can check the downloads section of Edge Panels. It links to the Edge Panel section of the Galaxy Store. You might find other sports panels which can show you the scores you want.I would like to know if there's a way to add NCAA men's basketball and NCAA football teams to the apps edge "sport" part. I see pro leagues but not college
