1. Gurky98's Avatar
    The issue I'm having is that showing all the time saying it's using up my cpu any idea what it is? I've done some good old googling and can't actually find anything about it.
    01-27-2019 02:56 PM
  2. Philipmom's Avatar
    it could be persistent notifications if you have that enabled. You have a Facebook notification active and that might be triggering it.
    01-27-2019 03:07 PM
  3. Philipmom's Avatar
    it's called notification reminders.
    01-27-2019 03:09 PM
  1. why don't google have stop command option to stop erase device data remotely
    Last Post: 01-27-2019, 02:03 PM
  2. Accessing a device over android device manager after a password change?
    Last Post: 01-27-2019, 03:04 AM
  3. why usb debugging invisible on my device ?
    Last Post: 01-26-2019, 01:39 PM
  4. Kindle downloads msg: " Will arrive on your device soonest."
    By Android Central Question in forum More Amazon Products
    Last Post: 01-26-2019, 11:33 AM
  5. Kindle downloads msg: " Will arrive on your device soonest."
