1. violetgreenblue's Avatar
    I have the galaxy s9+ and I just bought a headset to use with my smartphone for phone calls. However, the sound on the other line is way too loud. I've turned down the in-call volume as far down as it will go, but it's still loud. Oddly, the in-call volume does not go completely down to zero like media, ringtone and other call settings. I've tried making a call with earbuds to see if it was a headset issue and the problem still exists.
    I've also downloaded the app SoundAssistant but after playing around I don't see how I can directly lower in-call volume with that either.
    Please help.
    01-27-2019 04:10 PM
  2. lucianus_luciferus's Avatar
    you can't turn the in call volume down to 0. there is a mute button for that.
    and if the volume is still too loud on the lowest settings then maybe the headset is too sensitive? don't know...
    01-27-2019 04:30 PM
  1. My LG phone is stuck in "fastboot" mode and I can't exit out
    Last Post: 01-29-2019, 11:41 AM
  2. Why should I stick to the s7 edge and not upgrade to the s9 or the s10?
    By MaxCaufield in forum Samsung Galaxy S9 & S9+
    Last Post: 01-27-2019, 07:07 PM
  3. My Samsung Galaxy j7 neo software update
    Last Post: 01-27-2019, 06:45 PM
  4. Camera is only taking selfies& pics r upside down
    Last Post: 01-27-2019, 06:39 PM
