CypherMax
There's a new Always on Display settings in display mode settings , there's (tap to show), (show always), (show as scheduled) , did you check there.
Wow, I feel like an *****, that was the problem, thanks very much!
No It's and AT&T Carrier Phone Same as my AT&T Note9 running Pie as well.
why in the world did they move the clock over to the left? it's been on the right since inception. Is there a way to change this back?
Just an observation if anyone has had the same issue since the Pie 9 upgrade. My notification sounds for Text and Email went silent. I tried everything only to figure out that my Gear 3 watch was connected via Bluetooth. Once Bluetooth was turned off or it went into stand alone, the sounds came back. I don't recall this happening before. I guess they figure if you get the notification on your watch (vibrate or sound) it does not need to happen on the phone?
Mine don't either. Anyone find a fix?Anyone else's always on display not working after the update? Super annoying!
Thank you so much! This worked!There's a new Always on Display settings in display mode settings , there's (tap to show), (show always), (show as scheduled) , did you check there.
There is a setting in the Galaxy Wearable app. It's under Notifications. Once you click on notifications, the third one down is "Mute connected phone" Make sure that is not toggled on.
