1. Maria Clapham's Avatar
    Anyone know what can cause sudden battery drain. It goes from 50% to 6% in seconds
    02-01-2019 12:32 PM
  2. Maria Clapham's Avatar
    Phone is less than a year old
    02-01-2019 12:33 PM
  3. B. Diddy's Avatar
    That looks like a failing or defective battery. Does it happen repeatedly? If so, contact Samsung for warranty repair.
    02-01-2019 12:52 PM
  4. Maria Clapham's Avatar
    It did this a few months ago and I cured it with a factory reset. Don't want to have to do that again. No apps seem to be at fault.
    02-01-2019 12:59 PM
  5. Gayle Lynn's Avatar
    Sometimes an app can but difficult to detect which.
    After ruling out a cable. Charge adapter and such
    Know if a reliable 3rd party battery app?
    I'd try safe mode after wiping cache partition but you may need to reset the phone, and do not restore. Reinstall in groups from safest to least essential and consider whether something at least for now is safe.
    02-01-2019 01:15 PM
  6. lmandl's Avatar
    That was an S7 issue. I know 5 people who it happened to (including my son and daughter). My friends battery actually swelled so badly that the back separated from the front. Samsung did "fix" it even though it was over the year mark but it took some online shaming (posting videos of the damaged phone) to get it accomplished. My son and daughter upgraded to knew phones, as did the two other people. So, Samsung might still be having battery issues.
    02-04-2019 09:12 AM
  1. Just received the One UI/Pie update for my S9+ on AT&T
    By karelj in forum Samsung Galaxy S9 & S9+
    Last Post: 02-04-2019, 09:20 PM
  2. Battery Charger on app for device BLUETOOTH
    Last Post: 02-01-2019, 07:38 AM
  3. My battery is charging very slow
    Last Post: 02-01-2019, 03:52 AM
  4. Samsung S9 echo problems
    Last Post: 02-01-2019, 03:50 AM
  5. Pie Update on Verizon S9+
    By filmfan1138 in forum Samsung Galaxy S9 & S9+
    Last Post: 02-01-2019, 12:26 AM
