1. ABOSWORTH007's Avatar
    I've been using the full screen gestures instead of the navigation bar for the past couple days. One thing I can't figure out is how to enable the split screen view when using gestures? I'd assume you would just hold up on the recent gesture but that doesn't work. I might have to go back to the standard nav bar if I can't get split screen to work. That would be really poor design if there was no way to enable split screen with the gestures. If anyone knows how to do this, let me known
    02-02-2019 08:00 PM
  2. ABOSWORTH007's Avatar
    I just figured it out by searching on XDA. You have to click the app icon at the top of your multi-task view and then select split screen. See the pic. In this case I clicked on the G for the Google app and was presented with the options. Glad to know there is a way to do it, though it's much more cumbersome than long pressing the recent app button on the navigation bar.
    Mojave and mary beth hale like this.
    02-02-2019 09:20 PM
  3. mary beth hale's Avatar
    I just figured it out by searching on XDA. You have to click the app icon at the top of your multi-task view and then select split screen. See the pic. In this case I clicked on the G for the Google app and was presented with the options. Glad to know there is a way to do it, though it's much more cumbersome than long pressing the recent app button on the navigation bar. https://uploads.tapatalk-cdn.com/201...3853fa83ce.jpg
    The way Pie handles recents and split screen is indeed cumbersome. It's been a sticking point throughout the entire beta for me.
    02-03-2019 09:50 AM
  4. ABOSWORTH007's Avatar
    I might just have to go back to the navigation bar because of this.
    Gayle Lynn likes this.
    02-03-2019 10:51 AM
  1. My phone is hard to turn on from sleep
    Last Post: 02-08-2019, 02:27 AM
  2. Android system not working, did reboot now a downloading screen
    Last Post: 02-03-2019, 10:04 PM
  3. Alcatel Tetra won't ring , or notify when listening to my earbuds... Help?
    Last Post: 02-03-2019, 10:00 PM
  4. Upgrading my old phone to something better.
    By GoldCrazy2 in forum Ask a Question
    Last Post: 02-02-2019, 07:08 PM
  5. How to turn off wifi during sleep in android pie?
    By Android Central Question in forum Android Pie
    Last Post: 02-02-2019, 07:03 PM
