When trying to use the maps the full message is shown on a green screen "Google maps needs to change your location settings. When it's safe, check the notification on your phone"
The phone doesn't do anything when you click this notification. The message only comes up when the S9 locks. All location settings are enabled and I have reinstall android auto and cleared data also from Google maps as well. This message just stays on the screen and you can't go back out of it. All worked perfectly before updating to Android Pie.
This means android auto is unusable at the minute.
Help!
Help!
