    Just got the long-awaited Pie update on my Galaxy 9+. My battery life fell off a cliff. It used to be awesome. I have a lot of apps, but all are set to be asleep until I need them. My battery used to last 35-40 hours. Since the update yesterday, I am barely getting 15. I am NOT happy. A reset did not help.
    Please help!!
    02-06-2019 10:09 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It'd help to see your battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/gen...d-central.html
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    02-06-2019 01:02 PM
  3. Gayle Lynn's Avatar
    Too soon to judge. A lot of widgets churning things for first 3-4 days. Always helps to clear cache partition after that. Had the some with my 9+
    02-06-2019 01:23 PM
  4. gtyossi's Avatar
    Im having the same issue. Phone drains nearly 50% overnight-7 hours of doing nothing. Pie update is seriously draining my battery-whatsapp-image-2019-02-07-9.30.16-am-1-.jpgPie update is seriously draining my battery-whatsapp-image-2019-02-07-9.30.16-am.jpgPie update is seriously draining my battery-whatsapp-image-2019-02-07-9.30.16-am-3-.jpgPie update is seriously draining my battery-whatsapp-image-2019-02-07-9.30.16-am-4-.jpgPie update is seriously draining my battery-whatsapp-image-2019-02-07-9.30.16-am-2-.jpg
    02-07-2019 09:40 AM
  5. crossdeath's Avatar
    It seems like there is a problem with your mail client. Maybe try clearing the cache and setting it up again?
    02-07-2019 09:55 AM
  6. B. Diddy's Avatar
    Yep, I agree with crossdeath.
    nikosxri likes this.
    02-07-2019 10:38 AM
  7. Gayle Lynn's Avatar
    Also, JStream has not been updated in THREE years. Probably not fully compatible with Pie.
    You might want to uninstall and reinstall - can help. Or write developers while seeing if there's an alternative.
    Sometimes, A works fine. B does too. But put them together and there is mischief to pay.
    02-07-2019 10:58 AM
  1. AT&T S8 plus Pie Update
    By TMavC5 in forum Samsung Galaxy S8 & S8+
    Last Post: 02-06-2019, 09:19 PM
  2. Latest Update has caused so many problems!
    By Android Central Question in forum Samsung Galaxy Note 9
    Last Post: 02-06-2019, 12:48 PM
  3. Any chance to update android 7.0 to 8.0?
    By Android Central Question in forum Xiaomi Android Phones
    Last Post: 02-06-2019, 11:49 AM
  4. Any chance to update android 7.0 to 8.0?
    By Android Central Question in forum Android TV
    Last Post: 02-06-2019, 09:18 AM
  5. Any chance to update android 7.0 to 8.0?
