    Any suggestion?
    02-08-2019 04:43 AM
  2. Rukbat's Avatar
    Did you have t done by a repair shop? Bring it back and ask them to repair the damage they caused when they replaced the screen.
    You did it yourself? Open it up again and check every wire. It sounds like a wire not fully connected or one pinched somewhere. (And if it was inched to ground, hope it didn't blow anything.)
    02-08-2019 01:48 PM
  1. After repair, apps like s health or Knox doesn't work due to "root"
    By Zinelabidine in forum Samsung Galaxy Note 8
    Last Post: 02-08-2019, 04:06 PM
  2. Why cant my htc m9 airplane mode switch off
    By Android Central Question in forum HTC One M9
    Last Post: 02-08-2019, 02:50 PM
  3. I have a Samsung Galaxy Note 2 and can't locate MTP mode
    Last Post: 02-08-2019, 02:46 PM
  4. Replies: 1
    Last Post: 02-08-2019, 06:15 AM
  5. Unable to charge battery temperature too high
    Last Post: 02-08-2019, 02:20 AM
