1. IamSavic's Avatar
    Hey, anyone else having a problem with the task switcher on pie an never goin to the last app u were just in but it goes to the one beside it
    02-09-2019 12:56 PM
  2. mary beth hale's Avatar
    Are you using a 3rd party launcher? When I use Microsoft Launcher the recents behave the way you describe. When I switch to Samsung launcher my last used app shows up correctly.
    02-09-2019 08:15 PM
  3. IamSavic's Avatar
    No I'm not when I have more then 4 apps open it always goes to the one to the left app that's open an not the one I just came from
    02-09-2019 11:39 PM
  1. Samsung j7 prime screen touch problem
    Last Post: 02-09-2019, 09:46 PM
  2. Message app Problems
    By John A82 in forum General Help and How To
    Last Post: 02-09-2019, 09:41 PM
  3. Dual Sim problem - suddenly Sim 2 won't work
    Last Post: 02-07-2019, 03:11 PM
  4. Where are my Tasks???
    Last Post: 02-07-2019, 12:55 PM
  5. Replies: 1
    Last Post: 02-06-2019, 01:47 PM
