I updated to pie, factory reset, cleared cache and enabled the split screen in developer options. However its still not letting me use split screen on anything on my s9+. Anyone else have this issue?
gah, figured it out. Man they made that harder to find lol.
I just a gesture app that triggers split screen with one gesture.
Pretty much any gesture app in the Play Store has it. Fluid and Edge Gestures are the most recommended. Personally I use Samsung One Handed Operation+ from the Galaxy App Store.Would you mind sharing the name? Sounds good.
Where did you find it?gah, figured it out. Man they made that harder to find lol.
I know. Do we have those options in Pie?That's not Android Pie
See the post above you with screenshots. That's how Pie looks like.I know. Do we have those options in Pie?
Thanks. Pop up view is that I was wondering aboutSee the post above you with screenshots. That's how Pie looks like.
Hmm. I just noticed that Mary didn't have pop up view. Maybe the app doesn't support it and she didn't enable the force option to allow apps in pop up. I have it.Thanks. Pop up view is that I was wondering about
You double tap the recents button.I'm going to miss the list view. Is there a way to auto switch between apps like when we double tap the recent button twice?
