09-03-2019 09:01 AM
44 12
tools
  1. crossdeath's Avatar
    did you manage to solve this problem? i'm having the exact same issue, the sound notifications for facebook are barely audible
    05-17-2019 07:32 AM
  2. rocknrollover's Avatar
    Mine is same way.
    05-17-2019 11:28 AM
  3. Net_Surfer's Avatar
    It would appear no one has resolved the issue and Facebook has pushed out quite a few updates. I believe it is a Pie issue since there have been Facebook updates. This issue only occurred with me when Oreo was upgraded to Pie.
    05-21-2019 09:42 AM
  4. mesocyclone30's Avatar
    I've always noticed the FB notification sounds are so quiet I can hardly hear them when sampling them. Been that way on the last few phones I've had. LG G6 and GS7. and now the GS9+. I can't figure out why they're so quiet.
    05-21-2019 02:42 PM
  5. Net_Surfer's Avatar
    I have only started having that issue since upgrading top Pie. Prior to Pie all the sound notifications were good including Facebook. But now it is barely audible!
    05-22-2019 08:50 AM
  6. Rukbat's Avatar
    Try Ringtone Maker to set the level on any sound file higher. (Or you can copy it to a Windows, Mac or Linux PC and use Audacity to do the same thing.)
    06-14-2019 04:32 PM
  7. Net_Surfer's Avatar
    I tried that in Ringtone Maker and that did not work. In fact I am not hearing anything at all even after adjusting the volume to the max. And this only with the notification tone Sanguine. All other tones are ok.
    06-18-2019 08:59 AM
  8. Rachel Richardson's Avatar
    I have two Facebook accounts, one for family and the other for friends and acquaintances. Since updating to Pie I nave notice the notification sounds for both accounts is very low to the point where it is barely audible. All the other apps are ok and the volumes can be adjusted. But Facebook cannot. Has anyone had this issue? If so how did you resolve it?
    Me too! Following
    07-03-2019 06:59 PM
  9. Hquinn10's Avatar
    Me too! Following
    OMG!!! Finally someone who understands! I'm going through the exact same thing and I've literally lost my mind trying to fix it. I've disabled the app, deleted the data and cache, re-enabled the app and STILL nothing. No one seems to understand what I'm talking about. I did notice something that the Facebook settings has that the other apps dont and its "device-level notifications". Perhaps this has something to do with it?
    Following this until someone figures this out.
    07-27-2019 05:48 PM
  10. Hquinn10's Avatar
    So I did some more digging around and found that is definitely a Facebook app issue. On the Facebook app go to Settings & Privacy>Notifications>Push>Tone
    Here you can select what sound you want it to make. When you change it you'll notice that it's very low and there are no options to increase the volume. This is where the issue lies.
    07-27-2019 06:05 PM
  11. Net_Surfer's Avatar
    I got an Android update last night and it seemed to fix my Facebook sound notification issue. It is a bit loud but doable. There was also a Facebook update and that did not cause any issues.
    08-01-2019 11:46 AM
  12. ShaniaRanae's Avatar
    I just got a note 9 yesterday from my manager, everything is perfect except for the Facebook notification sound. Ive literally messed with every setting I could, and nothing has fixed it. I work on phones for a living and this is the most aggravating thing ive ever ran into!
    08-11-2019 11:53 AM
  13. Net_Surfer's Avatar
    Wait to see if you get a system update plus and Facebook updates. Facebook update the app every week.
    08-15-2019 02:37 PM
  14. gadgetuk99's Avatar
    Right guys I have same problem, I'm on Android 9, and yes Facebook system , no where to change the notification sound even the vibration, I use an app called notificon - notification sound manager app, here you can set the tone or voice you want to use, so yes you can use another sound that you have increased the volume of, and it works, let me know if you try this.
    08-27-2019 03:35 AM
  15. gadgetuk99's Avatar
    Sorry seems that didn't do it either, will look more into it today
    08-27-2019 04:22 AM
  16. gadgetuk99's Avatar
    08-27-2019 05:06 AM
  17. gadgetuk99's Avatar
    Ok in the app setting you can change the notification volume which is set at 7, increased it to full on and now you can hear the notification much better, just tested it and seems to work fine now.
    08-27-2019 05:17 AM
  18. gadgetuk99's Avatar
    08-27-2019 06:22 AM
  19. Net_Surfer's Avatar
    Do you have screenshots of this?
    09-03-2019 09:01 AM
44 12
  1. My LG3 lost all sound
    Last Post: 02-23-2019, 06:53 PM
  2. Why is contact specific notifications missing in lightflow?
    Last Post: 02-19-2019, 01:16 AM
  3. Notifications
    Last Post: 02-18-2019, 09:53 PM
  4. How can I disable constant bluetooth battery status pop-up notifications?)
    Last Post: 02-18-2019, 08:39 PM
  5. Default notification sound changed with update ?
    By DotsFar in forum Nokia 8 & Nokia 8 Sirocco
    Last Post: 02-18-2019, 04:59 PM
