    How do you setup double lock with fingerprint and PIN to lock your Galaxy s9+ phone? Need to set it up so it requires two unlocking to successfully unlock phone
    02-20-2019 01:53 PM
  2. lucianus_luciferus's Avatar
    i don't think you can do that unless you use a third party app.
    because the phone will unlock when you use one of the locking methods like pin, password, fingerprint, face/iris recognition even if you enable all of them.
    so maybe if you install an app that will somehow lock the phone then you can have 2 locking methods at the same time.
    02-20-2019 04:14 PM
  1. Best cases for Samsung Galaxy S10
    By shasticat in forum Samsung Galaxy S10 & S10+
    Last Post: 08-20-2019, 11:50 AM
  2. How to find battery %
    By Steve Swift in forum Samsung Gear S3
    Last Post: 02-25-2019, 02:15 AM
  3. Screen protector for Galaxy S
    By Android Central Question in forum Samsung Galaxy S
    Last Post: 02-23-2019, 04:35 PM
  4. How to upgrade my phone's android after root uninstall?
    Last Post: 02-20-2019, 03:26 PM
  5. Screen protector for Galaxy S
    Last Post: 02-20-2019, 01:02 PM
