1. Harlocksflower's Avatar
    I have tried to alter the color lens, do color adjustments, screen modes, visibility enhancements, everything! I have even restarted my phone and nothing works my screen still has a yellow tint to it. Help please. How do I put it back to the standard screen color and tint?
    02-21-2019 04:24 PM
  2. Tim1954's Avatar
    Sounds like you tried all the things to do. Maybe dial *#0*# and test the screen hardware there. You may have to get it replaced under warranty...
    mary beth hale likes this.
    02-22-2019 08:30 AM
  3. methodman89's Avatar
    What is your setting here? Did you download any blue light or nighttime screen apps?
    02-22-2019 09:03 AM
  4. Mojave's Avatar
    I agree with methodman89.....check to see if you have your blue light filter turned on. The blue light filter will use a yellow tint so you have less eye strain using your phone at night.
    02-22-2019 09:33 AM
  5. pontiac005's Avatar
    Did you get it resolved? Some great suggestions here.
    Tim1954 likes this.
    02-22-2019 10:37 AM
  6. SdM123's Avatar
    Sounds like you turned on the blue light filter
    02-24-2019 12:44 AM
  1. Nokia 6 (TA-1025) and Pie problems
    By Kzel in forum Nokia 6
    Last Post: 04-29-2019, 09:20 PM
  2. i have a galaxy tab A 8.0 and i need a new charging port where can i get one in reno nv
    By Android Central Question in forum Samsung Galaxy Tab A (8 & 9.7)
    Last Post: 02-23-2019, 01:53 PM
  3. Replies: 0
    Last Post: 02-21-2019, 03:22 PM
  4. My Galaxy S9 LED Indicator light stopped working.
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 02-21-2019, 02:25 PM
  5. My Galaxy S9 LED Indicator light stopped working.
    Last Post: 02-21-2019, 11:49 AM
