1. SeaBlonde's Avatar
    Before the recent "upgrade" my phone would show the time, date and other information on the screen when the phone was not otherwise being used. I like this feature. I don't know why it went away.
    Is there a way to make that work again?
    02-23-2019 12:16 AM
  2. li2327's Avatar
    It sound like you're talking about the Always on Display. Go to Setting, Lock Screen, and scroll down to Always On Display, and turn it back on. Hope this helps!!
    02-23-2019 12:28 AM
  3. SeaBlonde's Avatar
    It is on. You're right, though. That seems to be what I want. It's just not working.
    02-23-2019 12:34 AM
  4. cheezz's Avatar
    Turn on the switch. Tap to display and tick what you want shown.
    02-23-2019 12:54 AM
  5. krisqz's Avatar
    It's now tap to show by default on Pie but you can change it in AOD settings to always show.
    02-23-2019 02:36 AM
  6. joeldf's Avatar
    This is the answer, but the option is kind of buried...
    Go to "Settings" > "Lock screen" > "Always On Display" tap the label, not the switch (unless you need to turn it "on" first) > scroll down to "Display mode" > select your option.
    "Tap to Show" is the new default. "Show Always" is what you want. "Show as scheduled" is just another option - set it for certain times, like only at night maybe.
    lucianus_luciferus likes this.
    02-23-2019 10:51 AM
  7. SeaBlonde's Avatar
    That did it. Thanks everyone!
    Evidently, the settings were changed with the upgrade was installed.
    02-23-2019 04:07 PM
  8. joeldf's Avatar
    Glad you got it.
    It changed on me too after the update.
    02-24-2019 02:02 PM
  1. Root Hack New phone
    By Android Central Question in forum LG V40
    Last Post: 02-23-2019, 01:41 PM
  2. how do I remove the appmanager folder in photo gallery?
    Last Post: 02-23-2019, 01:34 PM
  3. Replies: 1
    Last Post: 02-23-2019, 03:13 AM
  4. i am trying to make my custom timeline view for Android
    Last Post: 02-22-2019, 11:51 PM
