    I have a GS9+ that was running Android 8 up until this morning when I got an update pushed down from T-Mobile. I used to have a little dot icon in the bottom left corner that I could double-tap on to toggle between fullscreen mode and regular mode. That dot seems to be gone.
    There are some apps that I sometimes use fullscreen and sometimes don't and I used that dot all the time. Does anyone know if there's a way to get that back?
    Thanks.
    02-25-2019 04:56 PM
  2. mary beth hale's Avatar
    Unfortunately that dot no longer exists. Have you tried gestures? Settings>display>navigation bar.
    02-25-2019 08:42 PM
  1. What does the permission Voice Recorder asks for, allows it to do?
    By pullpanelinoneswipe in forum Android Apps
    Last Post: 03-01-2019, 02:36 PM
  2. My contact list does not show the name
    By Android Central Question in forum Samsung Galaxy S9 & S9+
    Last Post: 02-26-2019, 01:00 PM
  3. My Samsung was making a water drop sound and now it is flashing two screens
    Last Post: 02-26-2019, 03:26 AM
  4. Replies: 1
    Last Post: 02-26-2019, 03:22 AM
  5. My contact list does not show the name
    Last Post: 02-25-2019, 04:27 PM
