Edge Lighting S9
Rae0516
3
Since the updated to Pie earlier this week, I cannot get my edge lighting to work at all. The only ones I really care about are gmail, texta and snapchat. I've tried every combination of settings I can think of. Tried disabling an app I thought might be interfering (light manager), and still nothing.
The only app I have been able to get it to work on is messages (stock texting) which I hate and don't want to have to use.
Someone suggested in another thread that if apps are being optimized that needs to be disabled, I found that setting for all the apps and turned it off. Still nothing!
Help?
Update, I can now get gmail to work when the screen is on, like I'm doing something else, but, it still doesn't work when the screen is off...
uOttawaGrad_22
